09-04-2025 11:34 PM
Hello everyone,
I am experiencing continuous disconnections with Apple iOS devices on a WiFi network configured as Open + Captive Portal with a corporate web page redirection.
The issue occurs in the following scenarios:
Each time the device roams between different APs.
Even when staying connected to the same AP, the captive portal page keeps reappearing roughly every 2 minutes.
We are noticing this behavior much more frequently with iOS devices compared to others.
Has anyone encountered a similar issue, or do you have suggestions on possible configuration adjustments or workarounds?
model APs: R350
09-12-2025 05:20 AM
Hi PatrickV
What is the controller and AP version here in use ? Also what is the configured parameter/value for below :
Grace period
session timeout
inactivity timeout
Best Regards
Vineet
09-22-2025 11:22 PM
Hi Vineet,
thanks for your reply. Here is the info:
AP version (AP R350): 7.1.1.520.830
Grace period: 720 minutes since disconnection
User connection: 5 days
Inactivity time: 86400 seconds
