Showing results forย
Search instead forย
Did you mean:ย
how to ssh from powershell to ruckus wireless AP (standalone)
I can start an SSH session to an R300 using these commandlets:
PS C:\WINDOWS\system32> $ruckussession = New-SSHSession -ComputerName 192.168.5.2 -Credential $cred
PS C:\WINDOWS\system32> Invoke-SSHCommand -Index $ruckussession.SessionId -Command $commands
But whatever the $commands, this gives output:
Host       : 192.168.5.2
Output     : {, Please login: }
ExitStatus : 1
This seems to be the same thing as when logging on via putty: One has to login al thougt credentials are sent with starting the SSH session. How can I overcome this?
6 REPLIES 6
Glad to know that you were able to fix it!
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
Jan1
Dear Syamantak Omer,
We are experiencing the same issue.
Could you please advice how to prompt the login over SSH ?
The example above also did not resolve the issue.
Jan
