hi, Concurrent users are support to Ruckus 7372, T301s & T301n AP?
swapnil_jadhav_
Please let me know how many concurrent users are support to Ruckus 7372, T301s & T301n Ap?
8 REPLIES 8
robert_lowe_722
Contributor III
Ok assuming that you haven't got any other WLAN's on the AP's and you are using both 2.4 & 5GHz radio's i would suggest the following numbers. Again, there is a difference between theoretical maximum devices associations (stated by Anusha) and the number at which users can expect an 'acceptable' level of service:
7372: 150 users
T301: 200 users
Even at these numbers you need to consider what the bandwidth and service requirements of the users are. For example if its for guest web access then a larger number of devices can be supported. If the use case is different and larger bandwidth or low latency is a requirement the numbers would need to change.
seanmuir
Contributor III
Concurrent sessions are related to  mulltiple factors.
Below are a number of these factors:
1. STA capabilities
2. Application being used
3. Frequency being used
4. Standard being used
5. Protocol being used
6. Number of SSID's  being broadcast
7. Environment - clean or noisy
8. Channel Size being used
Without knowing the above you cannot put a number on concurrent sessions.
Esteemed Contributor II
Robert posted the best answer above.  It depends on the Auth Type (WEP/TKIP take 4 mem slots compared to WPA2/AES),
and Association IDs are first come, first served.
See the table in KBA-4666: Where can I find the number of supported clients by auth type on Ruckus APs?
https://support.ruckuswireless.com/answers/000004666
Is there an updated version of this table that includes the R510 and R610?
