05-06-2022 02:31 AM
I have a ruckus T610...I can ping it but am not able to browse it or ssh... I tried different browsers but in vain.
Does anyone with the hint? please urgent support is needed.
Thanks.
05-06-2022 03:03 AM
Hi Claude,
Have you reset it to factory defaults?
Have you tried SSH?
When an AP is adopted to some controllers, the HTTP(S) interface can be disabled.
Hope that helps,
Darrel.
05-06-2022 03:13 AM
Hello Darrel,
yes, I reset it and I can ping its default IP but can't SSh or browse it.
05-06-2022 03:20 AM
Hi Claude,
That's unusual and it may be that the AP is faulty unfortunately. T-series APs ship with a 12-month hardware warranty to the original owner. If you qualify then I would recommend contacting Ruckus support directly.
Good luck,
Darrel.
05-06-2022 08:37 AM
Hi Darrel,
Thanks. let me contact ruckus support
