โ11-17-2024 11:00 PM
hi admin and all friends
i got problem with R310 ap...all server/controller ip already put via putty...after the ap is up...i cannot see it in my zone controller...other r310 working fine.. ..only this 3 ap is problem attach the pic below..pls help...
โ11-20-2024 07:16 AM
- Are there sufficient AP licenses in vSZ?
- Do you see any events/alarms in vSZ for AP MAC which is not joining?
Please share output of below commands via AP CLI/SSH:
get version
get rpki-cert issuer
get syslog log
Sagar Kuber
Sr. Technical Support Engineer
โ11-21-2024 04:00 AM
hi...
the license are ok..enought for all AP
pls guide me to check alarm..coz this ap is not connected to controller...controller ver is 5.2.1.0.515
cannot do get version...get rpki-cert issuer.....get syslog log...coz i cannot login to web portal after i connected to dhcp server...can do if i reset the AP...
โ11-22-2024 03:33 AM
Are you able to access the APs in question via SSH?
โ11-22-2024 03:39 AM
ssh mean using putty ?
