ZD Dashboard Usage Summary - anomaly?
max_o_driscoll
Valued Contributor
Just back from half-term and a look at my ZD Dashboard Usage Summary shows a minor gui curiosity...
For "# of Rogue Devices" shouldn't the 24hr period include the 1hr period?
So am I seeing
1hr info and then the previous 23hr info or...(to confuse you)
1hr info and then 25hr less the last hour...(I'll stop there)!
If max value occurs in last hour  the 24hr values should also reflect that maximum.
Image_ images_messages_5f91c3eb135b77e2478e3017_73ed4ef4644dfe85f3afcd15ebc9e216_RackMultipart20150223162741pe4-edb89448-e830-43f3-88f9-bbc6c684c278-2139254843.jpg1424692914
0 REPLIES 0
