ZD 1200 Guest network connection
Hi there,
We have a ZD 1200 with a number of AP's currently this is configured just for our internal corporate network, this is working well. in the past we have separate AP's for our guest network that connected to a separate port on our firewall so all traffic was just routed out to the internet with no contact with our network.
What I'm looking to do is to add the guest network onto the Ruckus system but also maintaining the distance from our internal network. my initial thought was to some how connect the guest SSID to the second ethernet port on the ZD which would in turn connect to the guest port on our firewall.
I'm not sure if the above is possible? if not what is the best way to setup the guest network? I've looked at the ZD settings to create a guest network but I'm not sure its going to work for us, but I'm open to ideas/help.
Thanks in advance,
Mick.
6 REPLIES 6
Hi Caveman,
Thanks for the suggestion!
Setting an ACL from controller to a WLAN adds it to APs WLAN interface. This means a wireless client connected to that SSID cannot reach restricted subnet.
Steps provided by me are for most of the standard wired network setup, however, using different routing rules one can always play with the traffic, so general config procedure may help specific use cases but not all.
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
itdept_head_me
Contributor
LOL...
you don't need to be an "expert" just have a clear head in what you want to  accomplish.
Obviously you will need
TWO zones for DNS & DHCP....
don't do like some people i've seen....
set   DNS resolvers to their internal  AD server on another subnet...
also  DON'T "break out"  the VLAN on the switch with an IP address, or you can have a very bad day where a mis-configured switch routes the traffic via 0.0.0.0 into your  existing infrastructure...
also watch your "trunk" statements
for sanity...
re-arrange your switch so that all the AP's come into a section of the switch as far away from other ports as possible and then "group" those ports...
too many times have I seen mis-labelled infrastructure cross route traffic due to a badly placed cable.
