Wireless Bridge P300 performance issues
Mike_Molyneux
Hi
We've got a pair of P300 bridges and we're having some issues with performance for devices on the other side of the bridge. If I ping the nearside root bridge IP then response is good, but if I ping the IP of the non-root bridge (and anything behind it) then the response time is generally very poor - high ping times and lots of packet loss. Other times (not very often though!) the response time is a lot better.
It's on channel 136 80MHz wide. Root shows the connected device as Rx RSSI 60 and ACK RSSI 61 and high signal strength.
A site survey scan from the root doesn't show any other APs. And on the non-root the survey I'm not seeing any APs on overlapping channels.
I just ran a speedflex test from the root and it shows root -> nonroot 33Mb/s throughput and 0% packetloss and non-root -> root 1.46Mb/s with 23% packetloss. But again, I've seen this a lot higher when the non-bridge is responding at a faster rate.
Devices are running 100.1.0.9.43 and line of sight between the 2 bridges looks clear from the photos I've received from site.
Thanks in advance for any thoughts.
Mike
0 REPLIES 0
