04-28-2022 03:11 AM - edited 04-28-2022 06:45 AM
When I select channel 100 with channelization set to 80MHz on my Ruckus R650 unleashed, what does it actually do? What range of channels or frequencies is actually used? What if I choose channel 128? Some people say that the chosen channel is the center channel and that the used frequencies are centered around it but that can't always be true. List of WLAN channels - Wikipedia
Or does it mean, if you choose 80MHz then any channel chosen between 100 and 112 inclusive will result in channel 100 through 112 to be fully used and if you choose a channel between 116 and 128 inclusive it will result in channel 116 through 128 to be fully used? That would mean you can't use channel 108-120 for example.
