Way should i bother upgrade ZF7372 to 100.0.0.0.127?
beppe_st_lbrand
Ruckus can't supply release notes for a regular user.
If i known this before we decided to go for ZF7372 i should have look for other products.
Never seen this kind of weak support model.
Kind regards,
Beppe
20 REPLIES 20
John Dong: You so right =O) on the spot.
I'm in standalone AP and all answers is that it's in mesh config and ZD can fix this.
I don't have ZD and I'm not going to need ZD and if thats the only solution, I will looking in to other brands and products.
::Beppe
About ISLAND. I quick fix i found out ( I don't give any support on it)
login via ssh and bring the ISLAND's down
set state wlan102 down
set state wlan103 down
munish_munish
Contributor
Hi Beppe,
Please share your email , i will send you the docs.
Munish
rw_van_der_knoo
Good afternoon,
I have the same remark to make; I can not access the release notes for version 100.x.
Why should I bother to update if one can not read the release/history notes?
I want to update my 7363 ...
With kind regards,
R.W. van der Knoop
cordelia_cordel
Contributor
Hi all, apologies you cannot see the release notes. I have made them public now so you can all download them.
