11-22-2021 01:55 AM
Hi Experts,
I have one R510 AP and I want converted to standalone mode, I have reset it and connected via 192.168.0.1 on internet explorer and tried to upgraded from local but for the moment I face with this message and doesn't let me to upgrade from local
and I have also tried to upgrade online but again I face with this message:
Do you have any ideas or solution?
The AP current firmware is: 200.7.10.202.94
Thank you for sharing your experiences,
Best
Ghasem
11-22-2021 03:02 AM
Should I put the file source address ?
I mean Like this:
fw set host 10.10.10.10 c:\file\1.bl7 ?
when I tried to use ruckus(ap-mode)# fw set host 10.10.10.111 c:\file
ruckus(ap-mode)#
There is no any error
Tnx for your help
11-22-2021 03:18 AM
Hello again,
I put these command and I again I face this error:
ruckus(ap-mode)# fw set control 10.10.10.111 c:\file\R510.bl7
ruckus(ap-mode)# fw set proto tftp 10.10.10.111 c:\file\R510.bl7
ruckus(ap-mode)# fw set port 69 10.10.10.111 c:\file\R510.bl7
ruckus(ap-mode)# fw update
/bin/sh: can't create /etc/airespider-images/upgraded.fromver: Read-only file system
fw: Updating rcks_wlan.bkup ...
v54_fw_update: download fwupdate1.ruckuswireless.com section=rcks_fw.main image=Image2 ctl_file=r510_9991_cntrl.rcks (/writable/fw/main.cntl)
Error: net_get_buf- FW_CTL_ERROR
**fw(957) : CTL Get Error
ruckus(ap-mode)#
any idea?
Best,
G
11-22-2021 03:23 AM
Hi Ghasem,
I would request you to please open up a case on our Support portal and one of our Engineers will assist you on remote to upgrade the AP.
11-22-2021 09:45 AM
Sorry if I missed this, any idea why there is a "c:\file\1.bl7" added at every command which you are entering on the CLI?
The format should be like below:
fw set proto tftp
fw set port 69
fw set control <firmware file name>
fw update
reboot
Not as
Note:
If the firmware file name is "R510.bl7, make sure you have this file copied on the root\shared folder of the TFTP server.
Sanjay Kumar
11-22-2021 11:26 AM
Hello and thank you for your note.
As I mentioned before when I did like your command I face with this issue, while I checked everything ( FTP permission, turn off firewall and access write@& read and.... )
after putting the first command I face with this msg:
I don't know whats wrong with this. 😞
OK
ruckus(ap-mode)#
