Upgrading single R510 from Unleashed to standalone issue
ghasem_ashjaei
Hi Experts,
I have one R510 AP and I want converted to standalone mode, I have reset it and connected via 192.168.0.1 on internet explorer and tried to upgraded from local but for the moment I face with this message and doesn't let me to upgrade from local
Image_ images_messages_619b691b14a66e5df7503c72_e347ec57a975f7c9b6d872cabaec137c_Capture111-b2dc60a7-fa5b-4ea4-8552-0b3cef6fa93f-1885519998.JPG
and I have also tried to upgrade online but again I face with this message:
Image_ images_messages_619b691b14a66e5df7503c72_9d73b0cd325443aba88c287176189362_Capture2-437cd660-904a-4c2c-ae3a-91b0c1c923ab-887736479.JPG
Do you have any ideas or solution?
The AP current firmware is: 200.7.10.202.94
Thank you for sharing your experiences,
Best
Ghasem
20 REPLIES 20
Should I put the file source address ?
I mean Like this:
fw set host 10.10.10.10 c:\file\1.bl7 ?
when I tried to use ruckus(ap-mode)# fw set host 10.10.10.111 c:\file
ruckus(ap-mode)#
There is no any error
Tnx for your help
ghasem_ashjaei
Hello again,
I put these command and I again I face this error:
ruckus(ap-mode)# fw set control  10.10.10.111 c:\file\R510.bl7
ruckus(ap-mode)# fw set proto tftp 10.10.10.111 c:\file\R510.bl7
ruckus(ap-mode)# fw set port 69 10.10.10.111 c:\file\R510.bl7
ruckus(ap-mode)# fw update
/bin/sh: can't create /etc/airespider-images/upgraded.fromver: Read-only file system
fw: Updating rcks_wlan.bkup ...
v54_fw_update: download fwupdate1.ruckuswireless.com section=rcks_fw.main image=Image2 ctl_file=r510_9991_cntrl.rcks (/writable/fw/main.cntl)
Error: net_get_buf- FW_CTL_ERROR
**fw(957) : CTL Get Error
ruckus(ap-mode)#
any idea?
Best,
G
@ghasem_ashjaei
Hi Ghasem,
I would request you to please open up a case on our Support portal and one of our Engineers will assist you on remote to upgrade the AP.
sanjay_kumar
RUCKUS Team Member
@ghasem_ashjaei
Sorry if I missed this, any idea why there is a "c:\file\1.bl7" added at every command which you are entering on the CLI?
The format should be like below:
fw set proto tftp
fw set port 69
fw set control <firmware file name>
fw update
reboot
Not as
Note:
If the firmware file name is "R510.bl7, make sure you have this file copied on the root\shared folder of the TFTP server.
Sanjay Kumar
@sanjay_kumar
@sanjay_kumar
Hello and thank you for your note.
As I mentioned before when I did like your command I face with this issue, while I checked everything ( FTP permission, turn off firewall and access write@& read and....  )
after putting the first command I face with this msg:
I don't know whats wrong with this. 😞
OK
ruckus(ap-mode)#
