Unleashed migrate to vSZ
I have several R510 routers running with the Unleashed software and I'm about to buy vSZ controller. Is it possible to migrate these routers to vSZ and the configuration from the Unleashed master??
Configuration of the WLANs, hotspot and similar things is not a problem, I can do it manually, what is more important is DPSK generated for the user devices by the IT-zero config. If I configure everything from the scratch more than 200 users will need to follow the procedure they have already done before (which was quite painful 😞 ) for auto provisioning.
Miro
2 REPLIES 2
martin_martin
Valued Contributor
In short, vmiro,
No, you cannot migrate any info from unleashed to vSZ
They are totally different controllers.
You can download the AP standalone software to make your unleashed AP ready for connecting to ZD and vSZ
Kind regards
Martin
Thanks for the info 😉
