01-26-2021 05:53 AM
Hi. I ran an upgrade on two unleashed R310s [to version 200.7.10.202.121]. The Master AP came back up but the other unit didn't and 'froze' with the PWR and CTL lights on steady. It doesn't show up on the Master control panel.
I have tried the reset button.
Any further suggestions very welcome.
01-26-2021 11:19 AM
Hi Matthew,
Check if you are able to ping the AP IP address from the network. If yes, try to SSH into the AP and check if upgrade on this unit was successful.
If you have already performed factory reset on this AP, it will accept default creds (super/sp-admin).
Once you are inside the AP CLI, run below commands.
get version
ping xxx.xxx.xxx.xxx (x= master AP IP address)
set director ip xxx.xxx.xxx.xxx (x= master AP IP address)
reboot
01-27-2021 08:58 AM
Thanks Syamantak,
unfortunately, there's no ping response (on the default IP) and it doesn't look to be picking up an IP address from DHCP either.
Kind regards,,
Matt.
01-27-2021 09:17 AM
Hi Matthew,
After factory reset, if AP is not accessible with its default IP (when connected to isolated network) then it is possible that device is faulty.
What is the power LED status? Stable green, flashing green or red.
