Showing results forย
Search instead forย
Did you mean:ย
The ethernet interface configuration on our Ruckus r610 keeps resetting.
goodwill_it
We have a Ruckus r610 with the latest unleashed firmware.  After SSHing into it, I used command:
set interface eth0 type general untag none vlans 1,3
VLAN 1 is for access and VLAN 3 is our guest network.  This setup works for around 2 weeks, then out of nowhere, I can't access the AP without setting VLAN 1 to untagged on the switch that the AP is hooked up to.  I check the interfaces and see:
eth0      WAN     Vlan-Trunk      1      1-4094
which is the default setting.  I have to run the set interface command again to get it working again.
I know I'm missing something, I just don't know what.
3 REPLIES 3
hayward_kong
Contributor III
Have you tried the newest one that just got released on Friday?
goodwill_it
I upgraded to the latest release and had no issues for over a month, then suddenly yesterday it happened again.
Same thing is happening to me on latest unleashed 200.15 for r710. Have you found any fix or workaround?
