03-13-2024 12:21 PM
I have a bunch of Ruckus T710 and T610 access points that are currently running 5.2.2.0.2069 firmware that I'd like to upgrade to 6.1.1.0.1274 firmware so that they are aligned with our Data Plane. When I trigger an upgrade on our controller for theses APs, the AP seems to complete the firmware upgrade, but then goes into what seems like a boot loop. It will just continually say "[system recovery for target failure]" after the upgrade completes. If I SSH into the AP, I can see that it is running 6.1.1.0.1274 firmware.
These AP models are said to be compatible with 6.1.1 per the Ruckus upgrade guide. Is there a common reason they would not be successfully upgrading?
03-21-2024 06:22 AM
It appears to correct this issue, the T710 and T610 models must be upgraded to 6.1.1 and then immediately factory reset and re-provisioned. Once this procedure is done, the rebooting issue stops and the AP functions as normal on 6.1.1 firmware.
03-18-2024 09:42 AM - edited 03-18-2024 09:43 AM
03-18-2024 10:04 AM
Hi @mpaine , Could you go to the Zone advanced settings and check what is the AP reboot timeout configured there? May I also know how many APs are there in that zone and how many of them are showing this behaviour?
03-18-2024 11:11 AM
In the zone I am migrating from (5.2.2) the settings are 30 minutes and 2 hours as shown above. In the zone I am migrating to (6.1.1), the settings are also 30 minutes and 2 hours. There are about 30 T710 and T610 units in this zone that exhibit this behavior when upgraded.
03-18-2024 11:29 AM
Thanks @mpaine , Could you please pull out AP support log from one of such APs and share the logs just beneath the string "### Kernel Oops ###"
03-18-2024 11:31 AM
This is what is displayed below:
### Kernel Oops ###
0xdf400000[0]: Image: type=1 index=1 total_boot=13
