Hello.
I'm planning to set management vlan 10 on ZD1200, and R600. Currently both devices has vlan 1 as their management Vlan.
First I connect R600 to my laptop using UTP cable and POE adaptor. Then I set ip address of my laptop to 192.168.0.110.
It was possible to change IP address and device name. I changed the Ethernet port to trunk from access mode.
But whenever I set management vlan 10 on R600, the connection between my computer and R600 lost.
How can I change the management vlan of R600 and check it works fine?
