12-09-2022 08:28 AM
Hi everyone,
I have some APs which are in areas where during the night no one is present. Does it harm the hardware if I switch them off every night (powering off the PoE port) and powering them on again in the morning or would it be better to let them just run?
Thanks!
12-12-2022 11:39 AM
Hello da_anton,
No, the nightly power off won't damage the APs (hardware) in the long run.
Vignesh
12-12-2022 08:39 AM
Hello Da_anton,
I am not sure if we have an option to schedule a power setting on Ubiquity switch ports. However, we should have an option to disable and enable the port.
You can schedule a WLAN on/off time as a workaround, so that on the specific time the WLANs will stop broadcasting.
Let me know your opinion about this.
Vignesh
12-12-2022 10:52 AM
Hi Vignesh,
the Ubiquity Controller has a REST service I can use to set the PoE state of a port. That already works.
But that was not the original intention of my question. The question is: will a nightly power off damage the AP hardware in the long run?
Br
Alex
12-12-2022 11:39 AM
Hello da_anton,
Vignesh
12-12-2022 11:45 AM
thanks!
