02-11-2021 08:51 PM
Hi, We have 2 VSZ High scale controllers which we use the one for old ZF AP's and the other one for new R series AP's. We have one site and created Zones and duplicated the WLAN groups on both the controllers then added 2 R310 AP's on the one and we have ZF7363's on the other one. My question, would there be an issue with the handover of the client devices from the AP's (R310) on the new VSZ to the old VSZ AP's (ZF7363) because the AP's are not on the same VSZ?
03-11-2021 10:38 AM
Could you confirm what do you mean by "handoff" here?
If you are talking about roaming, then strait answer is, roaming will not work between two different zone APs or between two different controllers.
Roaming will only work if APs are on same zone.
