S500 setup
Somethingfishy
Hello Group,
I have an S500 and have performed the master reset on the device.  Should I not see the configureme....
wifi network from the device?  I dont see that network.  What else could I be doing wrong.
Thank you in advance SF
2 REPLIES 2
8vin
RUCKUS Team Member
Hi @Somethingfishy ,
Yes, after the factory reset you should be able to see Configure.Me WLAN for initial setup. Please find the below article for more info:
https://support.ruckuswireless.com/articles/000010931
If the AP is still not broadcasting Configure.Me, we could hard wire a laptop to the AP Ethernet port with a static IP to access the AP. Please find the below article for guidance:
https://support.ruckuswireless.com/articles/000001853
Somethingfishy
Thanks I will give that a try
