03-21-2020 05:18 PM
03-31-2020 08:49 AM
04-07-2020 10:09 PM
04-08-2020 01:48 AM
08-11-2023 10:44 AM
Hi, I'm Felipe and I live in Chile.
I hope you found the solution. I also work with the unleashed version of Ruckus and I had the same problems.
The problem is generated in the leasing of the IPs in the network segment that the APs are in.
In my case, I configured the network segment of the APs with a 400 days lease on a Mikrotik router and the problems ended. Obviously the problem will occur again after the 400 days, but it will not be every hour hahaha.
Even if you set the IPs in the APs, they keep restarting, I recommend not to set them and let the equipment (AP) take IPs automatically.
I hope this serves as a solution.
Sorry if any concept was not understood, this text was made with a translator.
