08-13-2021 01:18 PM
Hello all,
so I have the Ruckus T710 with me and for the life of me I can get it to ping the default IP. I’m a little bit of a newb in this sector but my current setup is I have the ruckus plugged into a 48V POE adaptor that’s linked directly the computer. When it powers on, it gives me the “Configure me” WiFi but it has a password on it (which I found out was the serial number) but connecting to it doesn’t help and won’t bring up the unleashed webpage.
That’s when I decided to look into what the different blinking lights meant on the ruckus. My “PWR” and “CTL” lights both are green but blinking at a slow steady pace which I saw online that with the PWR light it means it can’t find a routable IP address which I’m not 100% sure why it can’t find that. And the blinking CTL light meant that it can’t connect to the unleashed network which I assume is a direct result of not being able to find a routable IP. So if there’s any info someone can give to help me get this AP fired up I would greatly appreciate it.
-Darren
09-13-2021 01:20 PM
Hi Darren,
You have to plug the AP to wired network connection like a model with ethernet cable or a switch which can feed internet to your AP and can also provide an IP address to it.
Once AP gets an IP and internet connection from modem/sw/gateway, you can access it and configure the wirelessLANs.
RUCKUS Networks, CommScope!
09-24-2021 02:40 PM
Anybody know a easy way to install it outside to a wall instead of the pole?
