Ruckus T310c Mounting Recommendation
david_henriques
I would like to know what is the best way to mount the Ruckus T310c to provide a good omni directional radiation.
There is any information regarding this subject? I can see in the installation guide it is possible to mount the device in horizontal and vertical way.
If it is mounted in a vertical way (in a pole) it will have the same omnidirectional radiation if it was installed in horizontal position?
David Henriques
16 REPLIES 16
Many thanks for the comment eizens, we integrated the Ruckus T310c in our smart pole and it almost in a vertical position so we need to pay attention to which area we want to have a good signal in a street.
eizens_putnins
Valued Contributor
T310c/d isn't exactly fully omnidirectional, it has  360x180 degrees antenna diagram.
When T310c or d is put horizontally, it has 360 degree diagram in horizontal plain, and 180 degree in vertical, so if you put it vertically, diagram turns accordingly -- there is no signal coming from AP back side. Similar with directional s and n versions (30x120 and 30x30), coverage depends on antenna orientation.
Eizens,
No antenna is fully omn-directional (360°x360°) beamwidth in both H and V planes. Such an antenna is only a theoretical 'isotropic' antenna.  https://www.sciencedirect.com/topics/computer-science/omnidirectional-antenna
Every omni directional antenna I've ever used or dealt with; is 360 degrees in the horizontal plane and depending on the antenna gain, varying degrees on the vertical plane.
E.g. A very high gain (>10dBi) omni-directional antenna will be only single-digit degrees in the vertical plane. E.g. This L-COM omni-directional antenna is "perfect for wide 360° coverage" but has only 8-degrees vertical beam width.
Thanks,
Darrel.
eizens_putnins
Valued Contributor
Darrel, you are correct, of cause, there is no in reality an ideal "isotropic" antenna. I was not saying that anyway.
I just tried to emphasize what is real diagram of Ruckus omni AP, as  often  people see AP as miraculous box which "provides coverage" without understanding that there are antennas and physical principles are the same for any device, even if you don't see any antennas connected to AP.
Ruckus omni AP diagram (and working principle) is very different from  what mentioned by you typical static omni antennas (which usually have 360 degrees in H plain and 30-10 degrees in vertical, with or without tilt).
This is typical misunderstanding about  how Ruckus AP antenna field works. Ruckus doesn't use static antennas.
eizens_putnins
Valued Contributor
Ruckus uses patented antenna system, which contains  multiple elements (up to 16) for each antenna, as well additional chip and antenna element switch. Chip identifies best pattern for each associated client and maintains antenna configuration table with client MACs. Antenna element switch actually connects elements in proper way to create antenna pattern for each packet, this configuration is done in real-time - packet-by-packet. It's named Beamflex, and it is really additional hardware and antennas, not just marketing name as other vendors like to have it.
So Ruckus AP antenna is actually  configured differently for each client and for that client it is not omni at all, it is slightly directional (up to 6 db gain). It is omni  only from point of view, that all clients in antenna diagram get same gain. Beamflex also optimizes antenna polarization, which is even more important, than gain itself for mobile devices.
2x2 dual-band AP has 4 such antenna fields, 1 for each transmitter in each band.  8x8 AP has 16. This makes  the difference.
So this is how Ruckus can have diagram 180x360 degrees - it is not diagram of antenna, but diagram of antenna gain provided for clients. Actually in vertical plain clients near edges get even slightly higher gain, as antenna elements can be combined more efficiently -- which is  beneficial for signal level on longer range.
