Ruckus R710 with unleashed but showing no AP
I have recently purchased an R710 on Ebay ( I have about 4 of these now and 2 T710's) I've had no issues in the past configuring my AP's but this one seems to be causing me quite a bit of trouble.
I had to connect via ethernet and SSH into the R710 to be able to upgrade the firmware to unleashed.  Now that it h as been updated there are no radios active as there isn't an AP assigned to the unleashed network.
As up see the unleashed config wasn't able to setup an AP and activate the radios.
Also, the broad casting SSID is still confgure.me-xxxxx and when connected to the configure ssid it does not assign an IP address so there is no way to actually configure through it.  Which is why I had so much trouble getting into this AP at first.
Image_ images_messages_5f91c3f4135b77e2478f940e_5f016532bdeac4c4839c5971f97ecb2f_RackMultipart2020050238262yfvz-9bc2d1e5-2aac-4525-a35f-ad55e263fc84-156111259.jpg1588424018
16 REPLIES 16
syamantakomer
Community Admin
Community Admin
Hi Ryan,
It seems this AP got configured as a second Unleashed network(Second master AP) than your existing Unleashed network.
Could you check if you are able to login into any other APs?
SSH into this AP,  run below command and see if you can see all the APs listed in "get election" output
get director ip
get election
Try factory reset on this new AP and add it back to existing Unleashed network.
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
Hey Syamantak,
Thank you for the quick response.  I updated my post but to clarify, this AP isn't going to be part of an existing Unleashed network.  Also I have reset this AP 5-7 times already and every reset I still cannot connect via the configure.me SSID.
Here is a screen shot of the Ruckus CLI, I am unable to use those commands. Sorry I am not the best at networking.
Image_ images_messages_5f91c44f135b77e247a17e2e_e88d135d065e49724c0b7acdbc563d3a_RackMultipart20200502843999nk4-cf421867-4fdc-4ace-ab27-527564424cd9-965095985.jpg1588426793
Image_ images_messages_5f91c44f135b77e247a17e2e_6e2fb10b3cbdfe36bc00d2f030976d6d_RackMultipart202005029347mppi6-09fe029c-340d-4eca-ac90-1bcb31a29fd2-2102570581.jpg1588427350
Hi Ryan,
If this is the only AP in the network then this must be master AP.
Try below commands (in same sequence).
ap-mode
get wlanlist
get director ip
get version
If factory reset did not worked then try reflashing the AP to standalone version and check if you are able to create WLANs and it is broadcasting SSID or not.
To check the SSID status, use the command "get wlanlist" and check if it is listing 2.4 and 5 G SSIDs (even when non WLANs are configured, it should show wlan interfaces with status as down/down).
If you don't see any WLANs from "get wlanlist" output then it means radio of this AP may be faulty.
Syamantak Omer
Syamantak Omer
Good Morning Saymantak,
It seems this AP is in standalone mode.  How would I configure this back to normal working order?
There seems to be no controller for this AP?
I am at my limit for knowledge in this. So i appreciate the help.
Image_ images_messages_5f91c495135b77e247afdc42_5867a1a3e1dc310e4eace83b0ec48597_RackMultipart2020050396624lm22-26a5f571-00ec-49f5-9a00-f66ae731c499-1156455730.jpg1588523834
