05-02-2020 05:56 AM
03-19-2022 10:58 PM - edited 03-19-2022 11:00 PM
If you're looking to run an unleashed environment with 802.11ac wave 2 AP(s), upgrade from non-unleashed firmware to unleased 200.10.x or 200.11.x firmware as a prereq prior to 200.12.x.
Reset the AP, then look for the assigned DHCP IP address on your router for the AP.
*If you plan to mix wave 1 and wave 2, then you'd want to target 200.7.10.202.127.
03-20-2022 08:45 AM
Figured it out. One of the APs had a different country code than the rest.
Once they were all on the same country code everything worked just like it should.
