07-11-2024 12:47 AM
Hello, I've recently reset a ZoneFlex R510, the network is appearing but the default password isn't working so I cannot access it, how do I fix this?
07-11-2024 02:03 PM
Actually I sorted this.
01-03-2025 04:45 PM
I have the same problem, how did you solve it?
01-03-2025 06:43 PM
Hi @eccware,
The default credentials after the factory reset is super\sp-admin.
For a proper factory reset, press and hold the reset button for 8-10 seconds and then release it.
01-05-2025 05:24 AM
Heya, you need to connect to it via a direct ethernet line, set your device's IP settings accordingly and then go to the web interface. That was the part I got confused on, the PW isn't the login for the WiFi network.
