Rockus R510 And R500. R500 Not supported :/
zvii_khara
Hi All
I have Configured Rockus R510. Firmware: 200.8.10.3.278. Added another Rockus R500 Firmware: 200.7.10.202.118.
I am unable to configure added R500. Check image:
 Image_ images_messages_5f91c400135b77e2479131c6_3dfa668c7675f4ebc7c369bee90ad40a_RackMultipart2020082311832211q-56dfadc6-8e3c-424b-930c-6c2c57f58aca-2056144850.png1598203039
R500 is now EOL i know but any chance to configure together? If not how configure it like new AP. I can't enter web based interface to R500. I see this massage in browser: Building the Unleashed Network. It may take a few minutes. Because of I am unable to make working this two AP together I am stucked now now 😐
Any ideas?
10 REPLIES 10
sanjay_kumar
Hi Electro.
R500 has detected another master (R510) in the network and it is trying to connect.
This is the reason you are not getting the GUI.
R500 is not supported in 200.8 release, so you either need to match the supported hardware on the 200.8 version or you need to downgrade the R510 to 200.7 so that R500 can connect.
Yes R510 is master and R500 trying to connect but because of version mismatch will be unable to connect. In this situation can I configure R500 like new AP without move and configure R500 in different network?
You can convert the R500 AP from Unleashed to Standalone AP from the below link
https://support.ruckuswireless.com/software/2431-zoneflex-solo-access-point-110-0-0-0-2005-ga-softwa...
syamantakomer
Community Admin
Community Admin
HI Electro,
I think it is much easier and beneficial if you simply factory default both the APs and downgrade R510 to 200.7 and then connect them both as a single Unleashed network.
This way you can avoid configuring and managing R500 as standalone and R510 as Unleashed.
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
