Reset Ruckus ZoneFlex 7372
mohd_izaimi_ros
Hye..i've reset my ZoneFlex 7372. What are the default username and password?
4 REPLIES 4
primoz_marinsek
Valued Contributor
Username: read
Password: manual
Or just turn the AP around and have a good year!
cordelia_cordel
Contributor
Hi Mohd,
Check out this quick setup guide for your ZoneFlex 7372. https://ruckus-support.s3.amazonaws.c...
Then, do a Ctrl+F and search for password and both should come up for you.
Happy New Year,
Cordelia
rahul_koul
Contributor
Hi Mohd.
Here is the information that you are looking for:
username: super
password: sp-admin
Also, as Cordelia suggested you can check the quick set up guide that provides more information in addition to the default admin credentials.
Have a happy new year!
Cheers,
Rahul
mohd_izaimi_ros
Thanks..username and password super/sp-admin only works when i'm use chrome browser..Happy new year..
Mohd Izaimi
