Registering R550 to Smartzone 100
vincent_voo
Does any share the similar experience where having difficulties in registering R550 to Smartzone 100?
R550 solo firmware version: 114.0.0.0.1432
Smartzone 100 version: 5.2.1.0.515.
It seems the R550 unable to find the Smartzone controller after set scg ip stage.
Get scg display: CONN_GET_ADDR_STATE
Ping to Smartzone 100 is ok.
Tried using R310 as testing, no issue in connecting to controller.
R310 immediately join to the controller after factory reset.
5 REPLIES 5
Just a thought are you an the same vlan?
What mechanism are you using for controller discovery?  DHCP option 43, DNS, manual?
@craig_burchfiel  yes both on same vlan 1
I'm using static on AP.
