01-30-2023 07:12 PM
I have an existing ruckus unleashed network that came with my Lennar home, it utilizes a ICX7150-C12 + two R510 access points connected with CAT6.
I am looking for some recommendations to upgrade to a Wi-Fi 6/6E ruckus access point that will still be compatible with the existing ICX7150 switch using POE and continue using the unleashed deployment model. I know the R550 is one option. Is that the best step up to get 802.11ax support without spending a fortune?
Thanks!
02-02-2023 08:01 AM - edited 02-02-2023 08:02 AM
Hi, you also can look for the R350.
Here is the comparison between R350 and R550:
02-02-2023 07:24 PM
Thank you so much!!! The R350 does seem like a great lower-cost alternative to the R550.
