11-21-2022 10:31 PM
I am not getting WIFI from my Ruckus R510 access points, i have troubleshooted with the truning off/on the power and cables and even removed from ceiling and tried with the all options. Now i am experiencing that my access points are not powering up. What are my options. Please advise.
Thank you,
11-22-2022 07:20 AM
I have added the photo what lights were on @Vásquez_Fer
11-22-2022 07:28 AM
Thanks for the update !
1-Seems to be that both lights are green
2-That orange cable where it goes ? if that cable goes to the Router ( ISP ) please move it to one of the twelve ports available in the 'middle part'
3-Seems that you switch may present some PoE issue (power over Ethernet) Please connect directly to your ISP Router ( local router )
To solve this you must access the command line of the Switch and do some diagnostics
4-For this we must locate the IP address (this is a logical address assigned by your local router (ISP) to the switch) I will leave a quick guide:
5-After that we must remotely access to device, I leave a guide on how to access to the switch
Here is a quick guide how to access via CLI of the devices
If you can access to the Command line should look like this
ICX7150-C12 Switch>
6-Write the following commands:
Note: Hit Enter to accept each command:
ICX7150-C12 Switch>enable
ICX7150-C12 Switch#show version
ICX7150-C12 Switch#show inline power
ICX7150-C12 Switch#show inline power detail
Copy and paste the results on the chat (here)
If you cannot access via IP we can access physical using a console cable
7-How to console in the ICX-7150-C12p
Once you are log in via console go to the Step '6'
Best Regards
Fernando Vasquez
12-07-2022 11:49 AM
I am having Apple Mac book M1 machine. So i cant able to connect it
11-23-2022 05:40 PM
I'm having issues now with my R510 unit that was installed by Amazon back in 2019, and I don't have any documentation or a number to call to have assistance.
