09-14-2023 09:32 AM
We have a network of R720s running firmware 6.1.1.0.1274. At least for testing purposes, will the R750 work on this firmware, or is the 6.1.1.0.1322 required?
09-15-2023 06:40 AM
Hi KK1313,
AP model R750 supports in version 6.1.1.0.1274. If needed you can upgrade the zone version to 6.1.1.0.1322.
09-15-2023 06:40 AM
Hi KK1313,
01-03-2025 08:09 AM
where will be download
01-03-2025 06:48 PM
For 6.1.1.0.1274, since the controller is already on 6.1.1, you can choose the AP zone >> Click on More >> Change AP firmware.
For 6.1.1.0.1322, below is the link for the software.
Upload the patch and then apply it as per above steps.
https://support.ruckuswireless.com/software/3646-smartzone-ap-patch-6-1-1-0-1322-lt-ga-ap-patch-1322
