R720 Unleashed fast flashing CTL LED
I am running newest Unleashed firmware. Was trying to do a factory reset but lost power before procedure can complete. Now I can't access GUI via 192.168.0.1 and CTL flashes fast. Can this unit be recovered?
Thanks.
7 REPLIES 7
tony_heung
Contributor II
Best option is to open a support case with our technical team who can provide further assistance on the hardware reset and verify the flash status.
syamantakomer
Community Admin
Community Admin
Hi There.
Try doing a factory reset by pushing and holding reset button for 12 seconds. Once done, try to access default IP or DHCP assigned IP.
If still not working then open a case and they will verify.
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
Thanks, got it working now.
I have ran into another issue. I am using AC power supply (740-64277-001/ 48V .75A). In GUI, I got a warning stating "not enough electricity power provided". Do I need to configure the AP to recognize its getting AC power source?
Thanks again.
Not required.
Wait for sometime, error should disappear automatically.
If not, then you may have to check.
Syamantak
Syamantak Omer
