04-06-2025 09:04 PM
Hi All,
I tried to join R710 to ZD1200 but AP keep reboot. I checked AP syslog and found below error message:
Mar 14 16:11:16 RuckusAP daemon.info Firmware Daemon[1151]: rks_fw_update.c:407 net_get_buf() NET_CLOSE() rc1=58
Mar 14 16:11:16 RuckusAP daemon.err Firmware Daemon[1151]: rks_fw_update.c:410 net_get_buf() curl error: 58, Problem with the local SSL certificate
Mar 14 16:11:16 RuckusAP daemon.err Firmware Daemon[1151]: rks_fw_update.c:4691 v54_fw_update() Error: could not get control file
Mar 14 16:11:16 RuckusAP daemon.notice Firmware Daemon[1151]: failed|control file download problem
Mar 14 16:11:16 RuckusAP daemon.info Firmware Daemon[1151]: rfw.c:502 do_fw() **fw(1151) : Control File Download Error
Mar 14 16:11:16 RuckusAP local2.err syslog: Firmware update error(252)
It seems ZD try to push new firmware to AP but AP missing local certificate.
Is anyone experienced same problem and solution ?
Many Thanks
07-24-2025 04:40 AM
Hi Ken,
Hope you're doing well.
Could you please let us know if you're still experiencing the issue? If so, kindly share the following details to help us investigate further:
For additional support, you can also create a case using the link below:
https://support.ruckuswireless.com/cases/new
Ashwin M
07-24-2025 09:37 PM
Hi Ashwin,
Thank you for your reply!
We can't solve this problem. We bought a new AP and replaced to a R650 finally.
Rgds,
Ken
