R710 AP does not support MESH on ZD1200, SW ver. 9.12
carlos_garcia_i
4 REPLIES 4
Esteemed Contributor II
The ZoneDirector 1200 has to have Mesh enabled.  Then, all APs will support Mesh (between like radios).
Thanks man..
Anusha_Vemula
Community Manager
Community Manager
R710 is a wave-2, 802.11ac Access Point. Smart Mesh is supported for wave-2 APs from 9.13 version.
Below is the 9.13 release notes.
https://support.ruckuswireless.com/documents/1104-zoneflex-9-13-ga-release-notes
Please upgrade the ZD to 9.13 or above versions and you will be able to configure mesh.
- Anusha
Thanks Team,
I will try to upgrade the ZD1200 to 9.13 and let you know...
