R700 not xmitting on 2.4GHz
jon_dean_chjxpw
I have 5 R700 Waps and a ZD 1200 and two of the WAPS are showing an amber light for the 2.4GHz band, I am trying to figure if they are faulty or there is setting that is preventing them xmittin, I am not an IT giuy and this is all new to me. Any help is sincerely appreciated
4 REPLIES 4
vivek_gupta_eaj
Hi Jon,
The Amber light indicated that the WLAN is up but no clients are connected.
Vivek
Hi, thanks, I just updated my post, the issue is that I am unable to connect 2.4 GHz equipment to my WAP's, In the past with other WAP's I have seen two connections available 2.4 and 5, on my current setup I only see one SSID and I assume its 5GHz. How do I know if there is a 2.4 connection available?
Hi Jon,
You can SSH into the AP and run the below command and paste the output
get wlanlist
Vivek
OK. I am not on site now. Ill do that tonight and post the output of the query. Thanks - Jon
