R650 bricked after upgrade
nls_pct
I had the stupid idea of doing a firmware upgrade on my R650 manually throught the R650 homepage as the autoupdate (through url http://fwupdate1.ruckuswireless.com/ ) was broken . Since then, it shows a simple " Building the Unleashed Network. It may take a few minutes. " when accessing the r650 homepage on my browser.
I took a firmware from the R650 firmware page and here is what shows the fw show all now :
rkscli: fw show all
<Control Info>
control file /writable/fw/main.cntl not in flash
current primary boot image is Image2
---------------<Image1 FW header>
Magic:        RCKS
next_image:   0x380000
invalid:      0
hdr_len:      160
compression:  l7
load_address: 0x42000000
entry_point:  0x42008000
timestamp:    Wed Dec 18 01:19:46 2019
binl7_len:    24026976
hdr_version:  4
hdr_cksum:    0xC704
version:      114.0.0.0.1294    ( 114.0.0.0.1294 )
MD5:          3EB8C61483DD5581B458E9E1278EA2D6
product:      r730      (0)
architecture: 0
chipset:      0
board_type:   0
board_class:  0
customer:
Image Sign Type: Fully Signed Image(FSI).
---------------<Image2 FW header>
Magic:        RCKS
invalid:      0
hdr_len:      160
compression:  l7
timestamp:    Tue Aug 11 07:41:50 2020
binl7_len:    46153568
hdr_version:  4
hdr_cksum:    0x0E1B
version:      200.9.10.4.202    ( 200.9.10.4.202 )
MD5:          5C4195B9169D655D59C86C0F9084D9C2
product:      r730      (0)
architecture: 0
chipset:      0
board_type:   0
board_class:  0
customer:
OK
So I tried reupgrading the firmware through the CLI throught FTP and I keep having this error with any of the following firmware images I tried :
R650_114.0.0.0.1294.bl7
R650-200.9.10.4.233.bl7
R650-200.9.10.4.212.bl7
R650-200.9.10.4.202.bl7
rkscli: fw update
fw: Updating rcks_wlan.main ...
v54_fw_update: download 51.68.11.228 section=rcks_fw.main image=Image1 ctl_file=R650_114.0.0.0.1294.bl7 (/writable/fw/main.cntl)
Error: net_get_buf- FW_CTL_ERROR
**fw(13240) : CTL Get Error
rkscli: fw update
v54_fw_update: download 51.68.11.228 section=rcks_fw.main image=Image1 ctl_file=R650-200.9.10.4.233.bl7 (/writable/fw/main.cntl)
**fw(13833) : CTL Get Error
rkscli: fw update
v54_fw_update: download 51.68.11.228 section=rcks_fw.main image=Image1 ctl_file=R650-200.9.10.4.212.bl7 (/writable/fw/main.cntl)
**fw(15746) : CTL Get Error
v54_fw_update: download 51.68.11.228 section=rcks_fw.main image=Image1 ctl_file=R650-200.9.10.4.202.bl7 (/writable/fw/main.cntl)
**fw(16211) : CTL Get Error
Would you have any idea before I send my R650 back to RMA ?
Have a nice week,
Nicolas
1 ACCEPTED SOLUTION
I don't work for Ruckus. But I am a Ruckus partner since 2006. I use Ruckus support regularly, and it is very helpful. You just need to know what to ask and form the very beginning provide support with all necessary information to help you efficiently. Ruckus has very good support engineers actually, and they are very helpful. Of cause, we have the support contract...
Also, when I see the messages similar to "Ruckus is frustrating and I am going for different brand", I always feel surprised why people want to change a very good product (in my opinion - best on market currently) to something not that good, hoping that it will work better for them. There are bugs and problems with any product, so service is provided to resolve them,  and Ruckus support is definitely better than most leading vendors provide.
      But to get real help from support (or forum) you need to be able to provide all necessary information, not just state "I have R710 AP ad it doesn't work, what should I do?".
        When I create support case, I start for collecting all background information (controller serial, network structure, IPs, software versions, AP models and firmware versions, other relevant info) and error messages (screenshots) and / or logs, so when case is opened, I post all this info as attachment to case. This way I get useful reply in the very beginning, without wasting time to answer standard questions to establish the issue.
11 REPLIES 11
eizens_putnins
Valued Contributor II
As far as you can access AP, you most probably don't need to RMA it, but you definitely need to open service case with Ruckus (which is required to do RMA anyway).
Current status of AP is unfinished upgrade from standalone to Unleashed image, so you have in flash 2 different images, and you are booting from Unleashed one.
Don't use upgrade from Internet, use upgrade from local file - you may have some issues with connection (small mtu, etc), and file get corrupted on the way.
You can also use TFTP upgrade, but using WEB interface is more convenient.
Do you have access to AP through WEB?If yes, try update firmware through WEB to standalone image 114.0.0.0.1294 (probably better after "set factory" command).
@eizens_putnins thank you very much for your answer. I don't have acces to the web interface anymore. I only get the line " Building the Unleashed Network. It may take a few minutes. ", but I have access to the CLI and when I try to update to 114.0.0.0.1294 even after a set factory, it keeps returning the following error :
eizens_putnins
It seems that you still try to upgrade from remote ftp. As you have issues, don't do it. I always never use it, actually. Just make local upgrade.
Start from resetting AP to factory through CLI or button (I would prefer CLI, as you can see if it is reset). You need DHCP server on network to provide AP with address after reset.
When reset, use default credentials and try upgrade it ( see https://support.ruckuswireless.com/articles/000001551 for details about ftp/tftp upgrade . For that you need to run tftp server on your PC, and put there both image and control file (put them into route directory!). Control file actually say to AP which file to download and what is expected file length.
It is just text file with content (make it in notepad):
[rcks_fw.main]
0.0.0.0
*filename of firmware*
*file size of firmware in bytes*
Name of control file can be any, for example cntl650.rcks. Put real image file name and it's size in the file (you need to find size in the image file properties -- size, not "size on disk"). Example of control file content:
[rcks_fw.main]
0.0.0.0
R650_110.0.0.0.675.Bl7
10717180
Commands to upgarde are:
fw set control <the control file name>
fw set proto tftp
fw set port 69
fw set host <IP of TFTP server>
fw upgrade
So, say your PC with TFTP server (TFTP32 for example) has IP 192.168.1.100, controle file name is cntl650.rcks than you can  use such CLI commands to make upgrade:
fw set control cntl650.rcks
fw set proto tftp
fw set port 69
fw set host 192.168.1.100
fw upgrade
If still is any problem, open case with Ruckus support (and probably provide them remote access to AP). Support will fix issue or RMA the device... Without additional support replacement is RTF, and takes 3-4 weeks normally, but as Ruckus APs fail very rarely, it is not a problem to get them replaced if it happens.
Type a product name
