09-03-2023 07:48 AM - edited 09-03-2023 07:50 AM
Hi
I have R650 AP joined the IoT controller but when I try to discover IoT devices I couldn’t be able to see any thing
The AP also joined the Zonecontroller 100 and I can connect my mobile with 5G ssid so it means the AP is functioning correctly
I am using zigbee protocol not ble
any idea about this issue?
mohammad
09-03-2023 08:02 PM - edited 09-03-2023 08:05 PM
Hi @Mohammadsaeed
Since the AP is connected to the IOT controller, this is between the IOT Radio and the IOT devices.
Couple of things we can try, make sure the IOT Radio is set to channel 25 with full power.
If still not working then we might need to check this over a remote session as there are multiple things we need to verify. Could you please open a support case so that we can check on this.
09-03-2023 11:10 PM
I found this link mentioned the plugins name but I didn't find assa abloy:
01-01-2024 05:29 AM
You should be able to see the AA in plugins list as below :
Note : Once the plugin has been enabled it will not show again in the list until deactivated/deleted.
Best Regards
Vineet
