R510 - Maximum RF Power - Region Code
holger_weil
Hi, can you provide a list or datasheet for the R510 with the RF Power Output regarding to a region code, for example Germany? Best Regards, Holger
5 REPLIES 5
martin_martin
Valued Contributor
Hi Holger,
Datasheets of our products you can find on the main website www.ruckuswireless.com under products.
The  power is set per country code, as each country has their own limits.
For Germany it is set for the maximum allowed in Germany.
Kind regards
Martin
holger_weil
Hi Martin,
thank you for your reply. I have seen the datasheet, but in this sheet I can see only the Maximum power 25 dbm / 2,4 GHz & 26 dbm / 5 GHz. Don't you have a list with:
USA 25 dbm / 25dbm
UK 20 dbm / 20 dbm
Germany 23 dbm / 30 dbm
or something else like that ?
Best regards
Holger
martin_martin
Valued Contributor
Hi Holger,
Sorry we don't.
If you need that specific information please contact your Ruckus dealer they can request it officially via the support channels they have.
Kind regards
Martin
monnat_systems
Valued Contributor II
country specific tech info is known to sales engineer of that region or they can arrange for you...
contact Local Ruckus sales here for germany
germanysales@ruckuswireless.com
or in general here -- https://www.ruckuswireless.com/contact
