R510 AP Leapfrogging firmware upgrades?
twolfend
hey folks
we have some old R510s running firmware version:  200.3.9.13.228
is it OK just to go ahead and 'leapfrog' all the intermediary updates to get to the most recent (200.7.10.202.127), or would we need to do each upgrade sequentially to get to the latest?
Also - are the network and mesh configurations reset/need reconfiguring after firmware upgrades or are settings carried over?
thanks
1 ACCEPTED SOLUTION
vasanth_edward
Contributor III
Hi @twolfend,
Thank you for reaching out to Ruckus Support.
Leapfrogging would generally reset the existing configuration, have to go through all the intermediatory upgrades to get to the latest & the config will be intact.
Vasanth Edward
5 REPLIES 5
I have a single R510 AP:  version 200.6.10.1.308
