11-05-2019 07:49 AM
our pair consisting of two P300s (firmware: 100.1.0.9.62) does not establish a link via wireless LAN.
The following entry appears again and again in the log file of the non-root bridge:
Apr 24 18:48:35 RuckusWB daemon.notice meshd[713]: Err 16 Failed to start scan
Apr 24 18:48:36 RuckusWB daemon.notice meshd[713]: wiredm_pick_wired_vs_wireless: Disqualified proposed_uplink b/c gw_detected=1
Apr 24 18:48:36 RuckusWB daemon.notice meshd[713]: uplink(wired=0)=null(0.0) best_wired=null(0.0) proposed=null( ,0.0,0.0)
Apr 24 18:48:36 RuckusWB daemon.notice meshd[713]: Advertise IF_code=- depth=- depth=1 downlinks=0 reason=
I have already checked the configuration for wireless LAN (channel, SSID, encryption) several times. I also reset the devices to factory defaults, which unfortunately didn't help either.
The P300s are supposed to establish a connection between two locations and are connected to the Ethernet port of the respective firewall.
11-05-2019 08:15 AM
11-06-2019 02:37 AM
11-06-2019 02:56 AM
