05-12-2021 07:43 AM
Looking to get the OID for the WLAN service
Need to be able to pull if it is disabled
05-12-2021 01:07 PM
Randy,
Give this link a look and see if it helps you https://docs.commscope.com/bundle/zd-10.4-snmpref/page/GUID-377DDEA2-D250-4C7E-8E0F-27E5E2EB6CCC.htm...
05-12-2021 01:10 PM
I tried that, but when we did the snmp walkthrough, there are parts missing to get the specific info.
We are going to test iso.3.6.1.4.1.25053.1.2.2.4.1.1.1.1.34.246 to see if this has the info we need.
Didn't know if someone had the specific OID already verified.
05-12-2021 01:11 PM
Let me go ask someone smarter and see if he is around.
05-13-2021 08:19 AM
Just heard back from the smart guy and this was his response "I did not find an OID which simply says radio 'ON' or 'OFF'. But If I disable all wlan services for a radio, and try to get the current channel for that radio, the OID returns “0”. That’s an indication that the radio is off." I "think" this is the OID he is referring to. He wasn't testing on the model of AP you are so I'm not sure if this will work exactly, but hopefully, this helps.
