Mounting recommendation needed on a parapet wall
steve_rosenthal
I need a recommendation please. I have a job that requires (4) 7762's be mounted on a parapet wall and then 'goose neck' so the AP will hang over the edge of the roof facing down. We've successfully used j-post/ satellite mounts previously, but in this case I need to overhang the roof. I need some specific mounting suggestions...
6 REPLIES 6
monnat_systems
Valued Contributor II
Hello Steve,
Take a look here - http://c541678.r78.cf2.rackcdn.com/da...
i think partnumber in the doc - 902-0165-0000 should meet your needs.
Hope this helps.
steve_rosenthal
thanks for the quick response - I have the bracket that secures the AP to a structure. pole. What I need is the hardware that I can mount this onto.
I cannot mount on the outside of the building, so I must mount on the inside/ parapet wall, and then the piece needs to go up & over the wall. I see many products online - but I'm looking for some real help from installers who deploy these outdoor AP's regularly. What works for you when there no existing hardware on a commercial building or school to mount your AP's - what do you use on a parapet?
monnat_systems
Hello Steve,
I have not done outdoor mounts so just trying my best to give you what i know.
Take a look at below URL - there are quite a few hardware which may help you out:
http://www.thefind.com/electronics/in...
hope this
steve_rosenthal
Is there anyone on the forums that has experience installing OUTDOOR WAPS on a building with parapet walls? I am really looking to the ruckus community for some suggestions ....
