Our company has 9 ZoneFlex links using Ruckus 7731s as P2P services over 5.8GHz. They all have very good line-of-sight paths. The links range from 2 Kms to 22 Kms in length and they all suffer from interference (as shown in the logs). The signal strength is between 20 and 35. The geographical area is very isolated with only an 850MHz public cellular system used in these areas. Once the reported interference is constant, the links drops for seconds to minutes and generally recovers. We have implemented a reboot after 2 minutes in case they freeze in this failure mode.
I would like a reason for these events and is this normal for this equipment?
Thanks.
