How to hard-reset ZoneFlex 7762-T without a shunt
Dear all,
I'm now having only one ZoneFlex 7762-T, which was earlier connected to a ZoneDirector/FlexMaster. Now I want to reset that 7762-T to Factory Setting, but I don't have a shunt, then what can I do?
When I turn on my 7762-T, after some seconds, the power light becomes green, and the status light is amber, and is flashing slowly, and using inSSIDer tool, I can see a hidden wifi network. On my laptop, I set the Ethernet IP address to 192.168.0.2, and connect to the PoE_In port. The 7762-T is powered either with PoE or 12VDC.
I wonder what the shunt does. Is it just short-circuiting pin 3&4? I tried to short-circuit those two pins while PoE powered. The status light was turned off for some tens seconds, and after that, it got slowly flashing again.
Thank you very much!
4 REPLIES 4
