How to enable R610 Port 2 and configure as Link Aggregation on Ruckus-Unleashed?
leo_chung_fsn1v
Dear all,
Does anyone can help to enable the Port 2 on R610 (picture as below) and how to use it as Link Aggregation?  Thanks a lot!
Image_ images_messages_5f91c3f5135b77e2478fad79_0c2870c25f564b7cf5bd217c0ada458f_RackMultipart20190519158021jy8-9970a424-52fd-4a41-91de-1400631c42af-474786328.png1558278493
7 REPLIES 7
Ankush_Chandan
RUCKUS Team Member
Hi Leo,
Admin and UserGuide are same. Here is the direct link to download:
https://support.ruckuswireless.com/documents/2404-ruckus-indoor-ap-110-0-user-guide/download
The LACP configuration is only available on CLI and if you are having trouble following instructions, please Contact our Ruckus support team.
-Ankush
sebastiao_paulo
Hi am getting same problem after my ZD damaged, i can't find options to enable port 2
Hi Sebastian,
By default none of the AP ports are blocked or disabled (from configuration point).
As long as AP gets 802.3at or at+ power from switch, both the ports will be operational. If AP gets 802.3af power, second port and USB port will be disabled.
To check power mode, run below command from AP CLI.
get power-mode
To force AP from Auto power to at power, run below command
set power-mode at
If AP is managed by ZD or any other controller, try changing the AP zone or AP group specific AP model settings and choose manual power over auto and set it to at.
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
Type a product name
