07-13-2022 01:40 PM
I have two R500 APs running 200.1.9.12.62 in Unleashed mode. I want to upgrade them to the most recent AP firmware. They have internet access, but clicking the "upgrade" button tells me that the server cannot be reached or the file not found (no indication of what server or what file). The documentation has screenshots showing a Local Upgrade option and I've downloaded the latest firmware for the R500 (200.7.10.202.127) but I do not have a Local Upgrade option on my admin portal.
How do I upgrade this when the automatic upgrade fails and the local upgrade option simply doesn't appear?
07-13-2022 06:07 PM - edited 07-13-2022 06:11 PM
Hi @jrowat ,
You can try the below set of command to upgrade the R500 AP offline, as 200.1.9.12.62 takes ZD based commands.
1:Find out the AP mac from the unleashed cli.
ruckus#show ap all
2: Switch to debug mode.
ruckus#debug
ruckus(debug)#
3: Use remote AP cli commands to upload firmware on the AP in debug mode, one by one.
if using FTP use below commands
remote_ap_cli -a ap-mac "fw set host FTP-UIP"
remote_ap_cli -a ap-mac "fw set proto ftp"
remote_ap_cli -a ap-mac "fw set user ftpuser"
remote_ap_cli -a ap-mac "fw set password ftppass"
remote_ap_cli -a ap-mac "fw set control R500_200.7.10.202.127.bl7"
remote_ap_cli -a ap-mac "fw update"
You might see execution timeout after last command.
Wait for few minutes based on your ftp speed.(2-3 minutes) and then execute reboot.
remote_ap_cli -a ap-mac "reboot"
OR
if using TFTP use below commands
remote_ap_cli -a ap-mac "fw set host TFTP-IP"
remote_ap_cli -a ap-mac "fw set proto tftp"
remote_ap_cli -a ap-mac "fw set port 69"
Wait for few minutes based on your tftp speed.(3-4 minutes), and then execute reboot.(on TFTP you will be able to see the upload progress, take some time after the upload finishes)
Note: Bold words in the commands are variable, like ap-mac: will be replaced with 58:b6:33:01:c0:c0 as an example, similarly ftp ip, ftpuser, ftppass, tftp ip.
07-13-2022 02:22 PM
I have also tried a firmware update via CLI and TFTP. Unfortunately, none of the various instruction sets work because the "fw set [etc]" CLI options are not in version 200.1, and none of the online CLI references is older than 200.6. Can anyone tell me how to do that in 200.1?
Hi @jrowat ,
ruckus#show ap all
ruckus#debug
ruckus(debug)#
OR
07-14-2022 06:29 AM
I could kiss you, this is working and the updates are happening right now. I'll mark it as the solution if they reboot and have the new firmware, once the transfers complete.
07-14-2022 08:19 AM
Worked perfectly! Well, as soon as they upgraded to 200.7.10.202.127 they tried to connect to an R510 that I didn't even know about, and there was some "interesting" trouble since it was running 200.8, but removing it and letting the R500s boot has brought them back up 100% and now that the R510 can see THEM, I can downgrade it to 200.7 and join it to the network. Thank you for your help, you solved my problem perfectly.
