Showing results forย
Search instead forย
Did you mean:ย
How to configure ZF7372
How can I configure an AP ZF7372 using a configuration file? I am using an AP-7372 as a stand-alone, and would like to use a preset configuration file to configure the AP. Doing it manually for each one is really painful.
7 REPLIES 7
well u shud get options to edit SSID settings in this version...
anyway... try upgrading this AP with version -- https://ufile.io/1zkjn
version - zf7372_9.8.2.0.15 i m giving is supported too...
I just checked on R500 with 9.8.2.0.15 and was able to see the options...
post upgrade... if you still dont see the options then perform a hard reset and still if you don't see it... then device is broken... get an RMA
you shud see options as in below screenshot
https://snag.gy/IaTS7N.jpg
Thanks! Working now!
