04-05-2017 08:44 AM
We are running 3 SmartZone 100 Controllers
We currently have 855 APs, all model
Firmware 3.2.1.0.245
Everything is running very well for our school district. We are now looking into using Google Expedition. The WLAN that the devices connect to:
Little bit about Google Expedition. The app is based on MDNS. (Yes another multicast wireless question). A user will start the app on one device and select to be the leader. The device then communicates out using MDNS. Then students start up their app on their device and select to be a follower. They start communicating out with MDNS to find and communicate with the leader.
Problem:
The devices work very when they all connect to the WLAN on the same AP. However when a device connects to the same WLAN on a different AP then they can't partake in the expedition. They can't see the leader and the leader can't see them.
This forum post is 3 years old. Is this still the expected solution for users to try?
If we do turn off directed-multicast as what the above link suggests:
Thanks in advance!
-B
04-06-2017 11:25 AM
04-07-2017 08:49 AM
@Michael Thanks for the info. We will give this a try.
UPDATE
After opening a ticket and doing more testing the following was found.
(First, the link above was for ZoneDiretor, not SmartZone)
The engineer on the phone help setup the directed multicast setting. After doing a test the app still didn't work.
We then changed the WLAN from being tunneled back to the controller to just dropped off onto a local vlan. Once we did that the app worked as expected.
We also tried it again by dropping onto the local vlan and without the directed multicast setting. This setting worked as well.
It looks like the problem is when a WLAN tunnels back to the controller.
04-11-2017 03:18 PM
