Getting a US-bought ZoneFlex 7363 to work on a UK ZoneDirector
I am in the UK and I have a ZoneFlex 7363 bought from the US. It is set to US and cannot be changed.
What are the issues with connecting to ZoneDirectors? Will it never connect to a UK ZoneDirector? Can the AP firmware be changed to allow the country setting to be changed? Can a US ZoneDirector be used in the UK. etc.
26 REPLIES 26
Sorry to learn up an old string, Im in precisely the same circumstance now with a US AP and a UK ZD. Did you figure out how to change the AP to a UK one by means of programming refresh or firmware by any means?
THANKS FOR ANSWERING ME PLEASE
see: https://appsync.biz/dafont/ , https://appsync.biz/123movies/ , https://appsync.biz/filehippo/
abilashpr
Contributor III
Hi karimovic,
Please contact support, who should be able to help you to reconfigure the US code AP work with UK ZD code.
We need to have remote access to the AP.
Abilash PR.
peter_w_9h7tcet
Contributor II
Just seen this - I have ordered Ruckus gear from the USA and I live overseas.  Already ordered ZD1200, ICX switch (plus access points planned soon to be ordered).  If I buy my APs in USA too will everything work or will the equipment know I live overseas??  I never envisaged that this would be an issue!!
Hi Peter,
AP do not knows if you are in US or overseas, it is more of a configuration thing which controls the use of a country code specific AP with a different country configuration on ZD or other Ruckus controller.
For example, lets assume I have purchased an AP with US product code (Keep in mind that I could have purchased an AP with WW product code as well) and I have a zone director, then below are things things I can or can't.
Can:
- If ZD is configured with its country code settings as USA and then I connect my US product code AP with ZD, it will work.
I can't:
- If ZD is configured with country code other than US (lets assume India) and I try connecting my US product code AP, then AP will not work with ZD as AP's country code cannot be changed from US to India (Country code mismatch).
So when you order the APs, it is must to check if you need a country specific AP or AP with WW code.
Use cases:
1- I am based in India and I know I will never move to other country or configure my APs to other country code. In this case I should buy AP with India country code (IN).
2- I am based in US but I may move to Canada or to a different country where I may need to use my Ruckus APs with a controller. In this case I should buy the AP with WW product code.
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
